Help. How to manually close sunroof QX56?
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
ChrisMc
Car: Qx56
Please help if anyone has advice. I have a 2010 QX56. Sunroof opened now won't close. Had similar problem last year and was told motor was shot but for some reason it opened this week when a friend accidentally pressed button.
Ilya
You've posted in the wrong forum, this is the M37/M56/Q70 forum. I have moved your thread to the correct forum.
ChrisMc
Car: Qx56
Thanks
marctronixx
well if you cant open or close it but it happened this one time, the motor and/or wiring could be damaged and making perhaps a loose connection.
if you dont hear anything to suggest the roof is trying to operate, it needs to be serviced.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
