BlazingCopperZ »
https://forums.nicoclub.com/blazingcopperz-u138921.html
Mon Jan 23, 2012 3:21 pm
I ran into the same problem, even after using a custom radiator. Of course the major issue is not having enough depth to put in a sufficient sized fan since the fan motor is so close to the crank pulley. I had both 10" and a 12" fan mounted as pullers, which barely had enough room to clear the crank pulley. It worked okay so long as the the temperature was below 80 degrees, anything above and it would start running hot in about 30 minutes (unless driving faster than 80 mph, haha).
Finally decided to bite the bullet last spring, and due to having too many other projects going on it wasn't drivable until a couple months ago. New setup is close to what you were not wanting to do, but I think is the most viable route. The radiator is now mounted so that the bottom is canted forward and the top is close to flush with the hood crossmember. I had to remove the center hood support, along with removing the gusset sections on the sides of the framerails. This now adds plenty of room for a shroud and big fan. I made the shroud out of 1/16" AL that stands off the back of the radiator about 1/2", and am using a Zirgo ZFU16S 16" 3630cfm fan, which was the most powerful fan that I found. The fan is actually rather quiet, and so far I have only gotten the temps to about 200 degrees, which rapidly cools back down to 185 or so when sitting at a stoplight. A great advantage to this setup is now there is enough room in front of the radiator to put the AC condenser back in, so maybe next Atlanta summer won't keep me from driving it much. Still need to add some gusseting to the hood latch and paint my new hood setup, but might take a while to get to it. I will take a couple pictures of it an post them next time I get a chance, hope this helps.
