HELP! How do you take off the crank pulley?
fiznat
Car: Grown up :(
working on my spare KA24DE right now in the garage and we're trying to take the head off... turns out that in order to take it off, you need the timing chains off, which requires you remove the lower timing cover which requires you to remove the main crank pulley. We got the big bolt out of the middle of it and have loosened all the lower timing cover bolts, but for some reason the pulley just wont come off.. anyone know how to do this??
QUICK! we're stuck right now and we wanted to get this done tonight!
MikeMurphy
Car: Guess
http://www.240sx.org/faq/articles/pullys.htm
The step is mentioned in that a few times IIRC.
MikeMurphy
Car: Guess
I read through it again and it doesent say much about getting the thing off, only the bolt. Maybe run some WD in there for awhile and give it another pull.
Nathan
Haha, I told him whats up on IM, lets see if he comes back successful ;) If not...we ALL get to mock and make fun of the nincompoop!
fiznat
Car: Grown up :(
lol well.... mock and make-fun-of away, cause we didnt do it.
..actually we decided to take the head off just by removing the cams and taking the upper chain off (instead of messing with that damn crank which will NOT come off, even with PB Blaster and a crowbar..), but turns out I dont have any sockets or wrenches big enough to fit those bolts! ...arruugh off to the hardware store it is!
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
umm...fiz, go to autozone, they have a tool made especially for getting the crank pulley off...(just rent it)
Drill_Sergeant
puller
Hijacker
Car: '92 240sx Convertible
'94 F-150
two words. Pully Puller. You'll probably need one that hooks around the lip of the crank pully. Thread the crank bolt back in a few turns, mount the puller onto that and then latch the puller handles around the lip of the pulley. Should pop off with little effort.
[Zero-S]
Yeah I didn't want to sound stupid and say crank puller puller, but alright.
JimLecesse
Car: 1992 240sx Hatchback - SR20DET
hey what size is the crank pulley bolt, i need to go buy a socket
Nathan
27mm for that crank pulley bolt. All you puller guys are just NO fun, I used a crowbar ;) Yes, I am lazy enough I didn't want to drive to autozone...sad isn't it? I'm just messing with you fizzy, cant fault you for not having a socket!
[Zero-S]
I've had bad experiences with crowbars+engines. It usually = replacement parts...
Charlie240sxt
Car: 95 240sx SE Ka24det!!! 98 audi A4
Yea it does.....but it gets it off:ylsuper :ylsuper :ylsuper
Hijacker
'94 F-150
[ZERO-S] wrote:I've had bad experiences with crowbars+engines. It usually = replacement parts...
I got lucky on my last bout with the crank pully. I tried the prybar method and knocked a small piece of the larger pully's lip off. I think it's insignificant enough that it hasn't thrown the balance off. I guess we'll see when I throw something in 10,000 miles though.
