HELP!!! how do i take out my dashboard?
S14-84
i found some info through the search but i couldnt really find the clear answer...im trying to fix my stero and its really hard to reach the wires and all that so i thought maybe i should take out my dashboard....do i have to unscrew the steering wheel and all that? if i have then is there different way to reach the stero's wire?thanks
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
what kinda stereo do you have that you need to take the entire dash apart?
of allt he cars ive doen stereo's in ive enver had to take the entire dash apart. i have taken out the consoles on a toyota truck though. explain more about the wire deal. if i understand ill try and help, maybe ill do a write-up?
Hijacker
Car: '92 240sx Convertible
'94 F-150
are you just taking out the center trim piece that surrounds the stereo? it should be a snap in piece.
drifter_for_life06
Car: Daily: '16 WRX
Exocet
thast what im not quite understanding
KDashy
Car: '97 Nissan 240SX
Yeah, you can even take as much as the trim around your climate control if you need to, but not the dash.
drifter_for_life06
Car: Daily: '16 WRX
Exocet
i dont think youd even need to go that far
S14-84
oh thanks for the info...the reason i wanted to take out the whole dash was for fun to see what is it like and trying something new i guess??anyways...if i only have to take the center trim piece? how can i do that? is there screws that i have to take it apart?? thanks guys
drifter_for_life06
Car: Daily: '16 WRX
Exocet
the trim is a pop n snap isnt it?
S14-84
oh and one more thing. some reason my whole speakers are connected to this sh!tty as amp and i really want to take that amp off and put everything back to how it was( i dont know anything about sound system and wiring) if i turn off the amp then whole sound goes out!! any clue?? thanks
drifter_for_life06
Car: Daily: '16 WRX
Exocet
ive comprised a very simple solution:
Circuit City: have them do it in their install shop
Best Buy: see above note
DaConfusion
Car: Nissan 240sx 1997
http://www.installdr.com goto your 240sx they have step by step picture diagrams. You cant mess up with this.
drifter_for_life06
Car: Daily: '16 WRX
Exocet
that works too
S14-84
thanks for the info...its awesome!!!
Wraith
Car: 1993 240sx coupe
Speakers connected to factory amp = Active Speakers ( Had to purchase the 240 manual direct from the factory 280$ OUCH ) but in fact that little amp is quite nice to leave intact unless you installing one. I left both of mine in and also have a Memphis 1000watt amp to boot. But even without the Memphis the speakers sounded great. When installing a new radio and leaving the amps in you will need the wiring maps to get it to all work right (or online guide from someone who has already done the process). From what I can recall I believe is is only two wires that have to be cut and spliced (been about years since I had to do it). But best of luck either way you go, and if need be I can break out the book and take a look for you
Wraith '93 240sx coupe
You dont have to outrun the Vette in front of you , just keep the Honda's in the rearview mirrors.
ZULU
THis is what it looks like without a dash S14.... trust me you dont want to take it out, A its not fun to take out and B its not fun to put back together.
KDashy
Wow that looks insane, not to mention you can easily crack your dash in the process, not fun.
S14-84
yeah...lol bad idea!!! thanks for the picture though list i know how it looks like..btw what were you doing? why is yours off?
ZULU
MY air bags blew which ripped the dash apart, i had to take the dash off to replace the bads. I also had a alaram system i needed to remove from the car.
Fun fun times.
slipnfall
Car: '06 D40
So do S14 owners have to drop their steering column to get the instrument cluster out? Just curious. In all my pulling and prying I couldn't get this out on my '92. Made things muuuch easier.
drifter_for_life06
Car: Daily: '16 WRX
Exocet
that picture is exactly the reason that if you ahve to take out the dash, id have an audio shop do it, or study on the topic for a while
DaConfusion
That looks insane!! It would be a fun day to take all that crap apart.
S14-84
actually that would be great because im still confused about the wiring..i took out the middle trim...but still stuck with wiring...???!!!thanks wraith!!!
S14-84
okay previous owner had some sh!tty *** amp setup. i mean i can see all the wires and the amp is hanging out from the back of the passangers seat. my friends were stepping all over the amp and the wires. now all the wires are jacked up and sound wouldnt work....i kinda figured out that all the front speakers and back speakers wires are extended and hooked up to this amp and here are some question i like to ask.....should i replace the wires and relocate the amp?or should i just throw this amp away and put it back to normal?i try to put it back to normal but i couldnt figure it out the wiring
S14-84
i will try to get some pictures...
S14-84
if its too hard to see then just click the link to it!!!
ZULU
No offense but that is the crappiest job ive ever seen. I redid all my wiring when i got my complete new system in. Ripped out all the stock speakers, amps , wiring. Let me tell you its alot of work and its confusing.
It took two days , I redid it all with new wiring, solder'd everything together to make sure i never have problems.
The rear speakers i redid and ran the wiring on teh side of the driver behind the seat, then ran it throught the center console by the airbag wiring up to the mp3 deck.you should see the car lol .... it was care metal .. i got some pics somewhere i'd have to find.
fun fun fun
Wraith
I believe the previous owner has screwed you, from the picture it looks as if when he installed the aftermarket radio (I say that because I noticed the preamp wires) he cut the actual factory connector out and tried straight wiring the system, instead of paying $8 for a wiring harness from Wal-Mart (sigh). With that said you are more than likely gonna have to extend the wires if they arent long enough, hopefully you like working with wires because looks like you have your hands full. Im going to the shop where me and couple of my friends work on our cars to get my manaul.
Here is the basic gist of want needs to happen to get the speakers to work without removing the factory amps. Which if you take alook at the one in the trunk it is pop-rivoted into place and is a ***** to remove. Ok the way the factory radio was set up is that when you turned the radio on it turned the amps on, and with aftermarket radios the wire that controls the factory amps are removed and you have to splice the amp hot wire into the radio power wire. That way you get sounds (angels rejoice and heavenly light). So if you are comfortable ohm'ing out wires you can locate the amps power with a meter. But if you have to go the route of bypassing your factory amps due to the previous owners ignorance then that will be nasty, basically you will have to rewire the audio system . But in any case will get the book today and will check post tonight to see how you doing.
S14-84
im so confused right now!!??!!!i might ask my friend to help me out because im so lost hahahahaanyways how much do you think its gonna cost me to rewire them because seems to me is that he did really bad job and i dont think just put it back wouldnt help so i might just rewire the whole thing again....depends on the cost!!! if its cheap enough then i will do it....
Wraith
The price to rewire it wont be to bad, wire is cheap and so are connectors. Thing that makes it tidious is if you do it right you want to remove all the old wires, connectors, amps ect. and it takes TONS of time. Like stated above atleast a whole good day maybe more. Wire and connectors though will run you all together (good set) under $35-45 depending on the vendor.
And just so you you know I didnt forget to consult my book on the hot wire for the factory amps is the BLUE wire running from them . But if you and your friend have the time I vote on a whole new set up bud, because it looks like a couple rats had a wild orgy in your wires there and left you with the **** to clean up Best of luck and let us know how it turns out.
S14-84
yeah thats not so bad....i might just do the whole wiring thanks for the info. i will get back with you with more info how it turn out
