HELP!! How do I Change cylinder head on 1988 Pulsar NX SE
Nigel's88nxse
Car: 1988 Pulsar NX SE
if anyone has any advice....ie. where do I start?? Twin cams..... is there anything I should do to make putting back together easier??Appreciate any help.
Dieselman
Car: 07 Ram 3500 Cummins Diesel.
Take some pictures if you can while you are taking it apart. That way if you forget where something goes you have something to reference.
Other than that keep everything as clean as you can and try to keep track of where everything goes!
Good luck!
Nigel's88nxse
got my camera all set. keeping everything clean is a good tip, thanks....just not sure where to start! the exhaust manifold is pretty straight foward but the intake is going to be a challenge I think....learn as I go I guess....
Dieselman
yea taking it apart is the easy part for sure. You'll quickly figure out just what exactly you have to remove to get the head off. Just try not to take off stuff that you don't have to.
Make sure that you clean all the gasket surfaces good before you start reassembly. You don't want any leaks when you are done so an extra couple minutes goes a long way there.
Nigel's88nxse
thanks for the tips Dieselman, appreciate it!
Dieselman
That's what we're here for!
