c-rad »
https://forums.nicoclub.com/c-rad-u19918.html
Sat Feb 26, 2005 1:01 pm
I don't really get your question...but if you are having the problem where the radio turns on, but there is no sound coming from the speakers, you need to hook up the "remote" wire on the headunit to both the power antenna wire (if you have one) AND another wire coming off the harness. I don't remember exactly which wire it is, but it turns on the amps attached to the factory speakers. Of course, this is all if you have the "Active Speaker" system in the car.
