Help HID lamp cover fastener
rover3l
Car: 1998 Q45, 2000Q45 Anniversary, 1965 Rover 3L,
The right hand side HID lamp on my 2000 Q45 anniversary edition is not working. I have checked the fuses and fusible links and they are all ok. I thought I would next change the left hand bulb which is working for the right hand side bulb to confirm that I do have a bulb problem and not something else.
However, I have ran into a stupid little problem which is that the fastener which holds the HID lamp cover in place is not anything I have seen before!
It seems to be either a Torx bolt or an Allen bolt with a protrusion in the center. The protrusion prevents me getting a tool to seat inside the head of the bolt. It is difficult to see because of its location.
Has anyone else removed one of these and if so, what did you use.
Q451990
It's called a "security head" - not sure if it's torx or allen but that's the name for it. You can buy the appropraite head at Sears, maybe Harbor Freight? Does the FSM tell you what size to use?
Heath
rover3l
Thanks for the quick reply. I will head down to Sears this afternoon to see what I can find. I don't have a FSM but I believe it is possible to download one if I remember. I will get searching
Thanks again
rover3l
Found it. It is a T20 security bolt
PANCAKES1
Car: 1999 Infiniti Q45T
They also caryy them at your local kragen/autozone but they only come in a pack w/ other bits for $10! I keep losing mine and have to keep buying them
rover3l
I got one from True Value Hardware this afternoon and I have swapped over the bulbs and yes one of them is non-functional. Looking at Infiniti Parts USA them seem to be about $170.
Anyone know of any other lower cost sources?
PANCAKES1
rover3l wrote:I got one from True Value Hardware this afternoon and I have swapped over the bulbs and yes one of them is non-functional. Looking at Infiniti Parts USA them seem to be about $170.
WOW! $170 for bulbs????You shouldn't have to pay no more than a $100 at the most on bulbsI get mine from a local shop here in SD for $60
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
There are a lot of cheap Chinese bulbs that will either fry your wiring or not last.
Stick with OEM or Sylvania, but be aware the new one will not match your old worn one in light out put or color temperature.
Q451990
Lots of bulbs on eBay. Not sure if they would fall in the "cheap Chinese" category Brian referenced, but I would at least look...
Heath
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
I'd say nearly 99% of the stuff on eBay is Chinese.
PANCAKES1
mtcookson wrote:I'd say nearly 99% of the stuff on eBay is Chinese.
Agreed!
