airmarbury wrote:2010 ex35 around 51,000km .... Have no idea what they will tell me tomorrow but I know my car is still under warranty. Does anybody know if I can ask for a new transmission or if they can not fix it, ( in my case, they made it worse ... ) will they give me a new car ?
Thanks
Like the other guys mentioned, I'd say that the problem is likely due to an electronic or sensor issue. While it's still possible that it could be related to a mechanical issue, I don't believe these transmissions have had many issues with their mechanicals.
If it so happens that a new transmission is required to get it fixed right, I wouldn't fret. It'll be covered under warranty and you'll have a fresh unit in there. As long as the dealer gives you a loaner it should be relatively painless
I'd be doubtful about you getting a new car. I'm not sure how the lemon laws work where you live, but at this point I have a feeling you wouldn't be eligible to get Infiniti to buy back your EX.
