I posted this in another thread of mine in the INFINITI GENERAL section, under "anyone wanna come help"
I checked the FSM for HIGH IDLE AFTER WARM UP (diagnostic procedure 33. EF-EC 176) and it talks about unplugging the MAF, and then starting and running the engine at 2000RPM for 30 seconds, and if the engine speed drops then its an air leak....
Quote » 1. Disconnect Mass Air Flow meter harness connectors 2. After starting and running the engine at 2000 RPM for at least 30 seconds, does the engine speed drop? --------> Discover air leak and repair. [/quote]Like I said earlier, I unplugged the battery for an hour or so, and the transmission is back to normal... Maybe its not used to having this mad power yet....
Now, just to get some 93 octane in it!! (running 89, i ran 89 when I had the old KS).....
Once it warms up a bit, I will check into the vacuum leak..... If I dont figure it out reasonably, I may just leave it and take it to a dealer sometime (or maybe to T3
