RonieRock »
https://forums.nicoclub.com/ronierock-u162404.html
Wed Jun 09, 2010 10:48 am
Helo all,
just got me a 1999 qx4...and feelin pretty good now
i have had 2 other nissan, maxima, and a 300zx
but here is my issue
I need to install an aftermarket head unit radio, and a single channel amp, when i got the car, it didnt even have one, jus a big gapping hole, lol
-the harness was cut, so i have to do the ineitable of re-wiring the entire car
wiring the hole car is no big deal, I already did it before i realized that the speakers were powered by their own amps
-my decision is this,
i already have a pop out dvd/radio and it has 4 pre-amp outs
i want to tap/splice into the factory bose system(i just paid tuition so for now i cant go all new and fresh just yet)
--i am an electrical engineering student so i think i should be able to get this together with jus a lil bit of help
the way i see it is that i am going to go from the preamps and splice into the bose system before the amps
--i removed all the speakers from the car and they r now sitting in my room, including the tweeters
the problem i am really having is that i do not know what wire colors are for what, so that i would know which to splice into
and i was tryng to upgrade the tweeters by de soldering the 3.3uF caps with 4.7uF caps and now those r done(gotta get some new ones, probably w/o the crossover...i have plenty of caps at skool and ill have my prof. help me solder since i dotn take that class till september lol)
so, does anyone know how to tap into this system
i kno i have got to send my preamp signal to the 3 amps(2 seperate fronts, and 1 for the rears) but what colors are they on the harness that connects the amps(that is all i have access to since the harness by the HU was cut and is non existant)
and i know i am going to need to send a constant power and ignition power to the amps as well
--i need these color codes as well
and does anyone know how i should re connect the tweeters, i have never had tweeters in a car and am oblivious as to how to wire them up,
--should they just be wired + to + and _ to _ off the bose speaker,
--does the front amps have a crossover built in, so that i can wire directly off of that?
--should i and can i wire them in any way directly off of the new head unit, maybe off the front stereo outs(the aftermarket radio does have mofset as well/ internal amp, 200watts split evenly to 4 channels)
any help would be greatly appreciated, i will post pics of the entire installation while it is being completed
also i kno its best to just get new spkrs, but funds are kinda tite rite now, and summertime is here and i totally refuse to be a loser driving with no radio to the beach
oh yea, wen removing the amp for the rear, there was a relat that said amp assy, what is that, is that for the amp or something else
