NZSLIDER »
https://forums.nicoclub.com/nzslider-u223251.html
Mon Jul 29, 2013 5:11 pm
Hey people i have a r32 with a series 1 rb25det in it from a r33 gts25t, has the usal mods ar60 turbo, tuned length manifold ,40mm tial wategate, greaddy plenum , FMIC, tial q blow off valve, r34 GTT injectors n pump , sard pressure reg, gizzmo IBC,n a few more bits n bobs its doing a few things
Runs sweet untill under quater tank of gas then starts surging? also like its got a mind of its own will come on boost n haul some days , but other days will come on boost (12psi) for so long then cut n loose all power the sometimes stall wen i come to a stop ? does not do this if i bring revs down to under 1000 rpm then put clutch in tho
i have changed my coil packs n plugs (gapped to .8) n insulated my coils still does the same ,am running a series 2 pink sticker MAF at the moment but have ordered a z32 MAF so will see the change wen install that i am also running a factory ECU
any help would be considered thanks heaps
