HELP HELP Car Wont Start
Jookmasta
so this started yesterday. car wont start for the life of it. will start if i push start it but thats hard to do if ur by urself. so let me describe the symptoms. car wont start at all. no noise no ticking. i thought it was the starter relay, so i got a new one and installed but no luck. i did check if the rubber gromet behind the clutch pedal was worn but it wasnt that cuz i held down the swith with my finger and tried starting the car but no luck. now im thinking its my alarm (clifford concept 400) since it has a starter and ignition kill. but the alarm seems to be working fine since i havent messed with it one bit since it was installed. it was installed like 3 years ago so its been a while. any idea what it could be? if i heard ticking, then it would be the starter but there is no noise. the engine doesnt turn over or anything. HELP PLEASSSSSSEEEEEEEEEE
allthrottlenobottle
Car: 91 s13
check ignition system where alarm was installed to see if there are wires that have come apart. check all fuses and rotor cap and plug wires. try a self diagnostic on the car and see if there are any trouble codes
