mhmiersma »
https://forums.nicoclub.com/mhmiersma-u182652.html
Wed May 23, 2012 9:23 pm
Memphbull52,
Do you have a code reader? Pulling the code would really help narrow down the issue. From your post, it sounds like the CEL is coming on, so I would assume there's a code that pops with it and stays on.
My guess, from what you have described, is it might be the p0340 code. I had a very similar situation in which the camshaft position sensor was out. It would start, run for about 30 miles, then die. Once it would die, I would have to let it sit for 5-10 minutes to cool, then I could start it again... Then it would only go about 5-10 miles before shutting down because the engine was already warm. There are 4 sensors that may be bad with that code, but having the reader will confirm its the sensors. Its a pretty common problem, but getting a code reader will tell you a lot more. Otherwise, its anyone's guess.
Hopefully that helps!
