After you have the fun of taking the plenum off, you'll probably answer this question "yes" out of fear of having to remove it again... not a lot of fun. I have found the best way to get the injectors out without damaging them is to remove the entire fuel rail with the injectors in them. Then put a deep well socket over the tip end of the injector and put it in a vice with some screws in the threads for the cap to give space for the injector to pop out. I don't remember the size of the socket, but it needs to fit in a way that won't damage the tip of the injector, but presses on the metal area around the tip without catching on the bottom of the fuel rail. These things are a real pain to get out, and brittle - so you're guaranteed to break them if you start prying them out with a screw driver or grabbing them with plyers.
I would ohm test them as well... it's very likely you have some on the way out...
http://www.q45.org has instructions under the technical section. Once they're out you can just test them with an ohm meter. Should be about 12-14 ohms cold. If you get over that they are beginning to fail due to ethanol exposure and will probably need to be replaced in the near future.
I think you're going to find that a lot of hoses and the runner gaskets will all need to be replaced if they haven't been done already. Many people try to avoid duplicating plenum labor by replacing all of the hoses, knock sensors if they're cracked or ohm incorrectly, the knock sensor subharness, etc. while they're in there. I spent over a week on my injector job cleaning and replacing everything, but that's just me.
At a minimum I would replace those runner gaskets, your throttle body gasket, and all o-rings with new ones. Be sure to lubricate the o-rings and mating surfaces in the fuel rails before you install the new injectors, and avoid twisting the injectors too much while inserting them to help avoid pinching or cutting your new o-rings.
Good luck!
Heath
