More than likely, he disconnected the battery and the regulator got out of sync. This isn't usually a huge problem with our Gs, but the Altima boys are CONSTANTLY having to reset their windows.Poyzinous wrote:Maybe your window was grounded to the regulator.
Your description started making me think about my wife...kmckis1029 wrote:+1
i cut the smallest hole possible and basically let the ground wire stretch the hole to the exact size so it was a tight fit... then I pulled the wire in the opposite direction (like if you were pulling the wire out) so there is no dimple in the rubber boot for water to pool in and eventually drip down...
