Help getting my CA to run better!!
looksLikeA240
Car: break dancing
its running well when it gets boost which doesnt come until late 3500 rpm which is laggy. It's a dog until boost and i'm wondering what might be the hold back. I have yet to replace the plugs, and i only put about 4 gallons of 94 octane in the 1/4 full pure **** gas that it had in the car (that i bought at an auction and was sitting for months on end). I hopeing changing these two things will give me a lucky break, but it feels shakey. It seems like its running rich and bogging down preboost. Any advice on a possible fix would be extremely helpfull and appriciatedthanksDustin
280hp
Car: racing , women and sports
check timing , tps, and make sure you are not running thestock ka ful pump and filter. if that doesnt fix it e mail me and i will help you some more
looksLikeA240
Car: break dancing
i'm running a 300zx tt fuel pump with a new 240sx fuel filter, timing is set at 25 (I tried all kinds of timing settings, maybe you know a better) TPS is set. I ran out the fuel tank and put in some good stuff. It seems to be running a lot better. I better buy some plugs. WOT feels rather smooth though, kinda weird.Thanks Dustin
280hp
is it still running rich?I had to get an afr to make mine run good.If you need it let me know because I ordered a stand alone engine management system, so I wont be needing the afr or the bigger maf.let me know if you're Interested.and does yours over heat any more or is it perfect now?
looksLikeA240
Car: break dancing
it runs quite cooler now. But seems to get a bit toasty in 9degree plus weather in traffic. So you think the preboost rpms just need a bit of leaning?
