Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Sep 18, 2008 7:42 am
Easiest way is to utilize a temp sensor and have the fan wired to that IMO. Nissan factory lower rad hoses from the '89-90 models have a fan switch in them (it was for the A/C fan).
I made a crappy MSPaint diagram a while ago on how I wire e-fans with a relay
Basically, you tap a battery power source (I just run a wire to the positive terminal) and use it to power the relay's coil and gated circuit. Then you run the power complete from the gated side to the fan. And you run the power complete for the coil side to the switch. Then you ground out the switch and the fan.
When the temp hits about 190 or so, it should complete the circuit and activate the relay. When the relay is activated, the fan turns on.
