help get this s14 ka timing right please!
SCKA24E
Car: 90 240 sx M
alright so i let it warm up ,turned off, removed TPS connector , turned on, rev 3 times, adjust idle screw to 700 rpm, and i have an old craftsman regular timing gun , i lined up the needle to the last mark, turned off re connected tps, drove around and noticed some bucking, hesitation mostly in 1st and second. lmk what u guys think my cars running like alright but hesitates in lower rpm. also checked TPS voltage was at .49 and 4.11 at WOT any help would be great, thanx
Modified by SCKA24E at 7:25 PM 8/6/2006
180fan
Car: 89 fastback
How was it before the timing adjustment? Does the timing light also have a dial on it for advance? If it does, make it go back to 0 degrees advance and adjust the timing again. Otherwise, I'd check out the timing again to make sure the distributor didn't move too much during the retightening.
