420_240 wrote:thanx for the help man i appreciate it... anyone out there with an s14 can you help me out????
420 on the f3 plug from the ka harness you have to connect the black/pink wire that is between the black/yellow and the orange wire on that plug. That is the one for the fuel pump the other black/pink is the one for the AC triple presure switch... do you have a copy of the ka plug wires? here it is just in case.
>1-black/red, ignition lead to injectors, coil>2->3-blue/red, rear defogger/electrical load signal>4-pink, washer switch>5-light green, ignition lead to wiper motor>6-light green/black, wiper motor high>7-light green/red, wiper motor low>8-brown, wiper off/int switch>9->10-black/yellow, fuel pump signal to F23, IACV-IAA>11-black/pink, fuel pump relay signal>12-orange, headlamp diode>13->14->15-purple/white, P/S oil pressure switch>16-yellow/black, AC switch>17-red, battery lead to ECCS relay>18-brown, igniton lead to O2 sensors, EGRC solenoid, EVAP purge/vent >solenoids, IACV, TPS>19->20-red, GST port>21-yellow, GST port>22-green, CONSULT port>23-green/white, CONSULT port>24-yellow/green, VSS signal>25-orange/blue, cooling fan high signal>26-yellow/red, tachometer>27-blue/yellow, wiper intermittent switch>28-yellow, temp gauge sending wire>29-black/white, ambient air temperature switch>30-orange, MIL lamp>31-blue/white, ASCD actuator power>32-blue, ASCD air valve>33-yellow/blue, 5th gear position switch>34-orange, start signal>35->36->37-orange/blue, recirculation relay>38-green/black, CONSULT port>39->40-green/orange, neutral position switch>41-blue/green, cooling fan low signal>42-purple, wiper variable intermittent switch>43-black/pink, triple pressure switch signal>44-blue/red, IACV-FICD signal>45-orange/black, triple pressure switch line>46-ornage/blue, AC thermo control amp>47-green/yellow, ASCD release valve>48-blue/black, ASCD vacuum motor
