PercieBlaze »
https://forums.nicoclub.com/percieblaze-u229019.html
Fri Oct 03, 2014 9:04 pm
So, my problem is my gauge cluster is getting power even with the ignition off and the key out. Also my Egi/Ecu relay continues too buzz.
Now if start the car then turn it back off again, the gauge cluster goes off and no buzzing relay, but if i turn the key to the on position without starting the car, the problem happens all over again.
i checked both front fenders to see if i had rubbed through the harness and it all looks good, so tucked em up high and out of harms way.
These are the things i have replaced so far in hopes of fixing it...
-Ignition switch
-alternator
-egi relay
-ECU
-the other computer that sits under the arm rest behind the e-brake
-ECU harness
-gauge cluster
-trans harness
-battery
