Jerosko »
https://forums.nicoclub.com/jerosko-u74418.html
Sat Aug 25, 2007 11:52 am
Hi i am new here and i am having problems with my gas tank.
It will not open no matter what i do. I read instructions on another page but need stuff clarified.
for example i saw this
1. Open rear hatch.2. Locate rubber gasket.3. Gently lift gasket edge away from carpeted sidewall.4. Lift carpeting enough to stick your paw in there.5. Helen Keller your hand towards gas cap.6. You will feel a smaller opening that your hand will fit through to allow access to the actuator.7. When you feel the actuator (it feel about the diameter of a pencil) pull it towards the rear.8. Gas cap should pop open, if not, while lifting actuator, press on the cap door like you normally would.9. Fill 'er up.
but i am not sure what this rubber gasket is they are talking about.
2nd i heard that you can somehow disconnect the lock feature on your gas cap so you can pop it open even if your doors are locked.
please help.
thanks
