HELP: Garage Door Won't Open with Remote After Attempting to Sync with HomeLink
bembol
Car: 2015 Nissan Murano SL AWD Cashmere Interior
I tried programming the HomeLink with our Garage Door Opener. I failed at it and today we can'topen our Garage Door with any of the Remotes.
It's late and can't contact Sears, it's Craftsman. Any ideas?
Thanks!
t2jokz
Car: Nissan Altima Coupe 08 3.5 SE / Infiniti QX56 2010 black
That usually happens if you're trying to set up with other garage. You have to do it again coz it happened to me also...i have to configure it again, press left most button and the 3rd button (with 3 broken lines) together, wait for a rapid blink then release then press the button you want to use together with the remote (i know you did it before)...it might be redundant but hope it helps...
bembol
Thanks. I tried it again, no luck.
My OEM's are in the Garage! I'm picking her up in two days too.
shift_mikey
Car: 2008 Altima 3.5SE Coupe w/CVT
This is a forum for the Altima, not Genie garage door openers.
But, i'd still like to try to help :-)
Try the following. Press and hold the "learn" button on the door opener itself until a little indicator light turns on. Then, press the garage door opener.
Thats just the GENERIC version (how you program the car for rolling codes too). If that doesn't work, take down the model number, and go to manufacturers website and look it up
