help! fuel pump wont run!
fireheadmt
just tried starting my sr for the first time. the fuel pump will not run when i turn the key on or crank the motor. i am getting power at the pump and i can run the pump just by sending power to it manually. i am getting power at the relay and at the ecu. the strange thing is i am not getting a ground shot back from the wire for the fuel pump in the ecu when i crank the motor.
any ideas?
thanks in advance
fireheadmt
found this on heavythrottle
Fuel pump not coming on Plugs by Battery may be wired incorrectly, they plug in but won't work without rewiring. Pump should run for 3 seconds then stop if flywheel not moving.
how do i know if they are wired incorrectly, and any other ideas?
Nismo_Freak
Car: 89 Nissan 240SX
How about you give us some info on what motor you have, and what car you have.
fireheadmt
oh sorry about that,
1990 s13 with sr20det red top (possibly a 94 because of the "finned" head)
62 ecubrand new harness with wiring service done by ueperformance, who did an excellent job
