HELP!!! Fuel disconnect?
killerpenguin2009
Car: 93 hatch current project
97 kouki stock sold
95 zenki stock traded
Hi my 91 240sx coupe had a front end collision and now it seems like its not getting fuel what could the problem be? Please help thanls
allenms240
Car: 1991 Nissan 240SX
Well you need to assess the damage basically. How bad was the collision? It the motor just cranking, dying, choking, etc etc.
costa_rican13
Car: 1993 s13 coupe
yup what he said^^ and also check your fuses in the fuse box, and make sure no wires were torn or anything, also the hard lines for kinks that run along the frame rail. If the car cranks then pull your spark plugs out and see if they are wet from gas. If they are, then getting fuel isn't your problem.
killerpenguin2009
97 kouki stock sold
Thanks I'll definitely have to give it a second look. Really I was mostly wondering if the car had a cut off switch like I think the koukis have a relay that you have to replace after a wreck.
