HELP! Frustrated Replacing Struts on 1998 QX4
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
I bought some new shocks and struts for my 1998 QX4 and I'm havings some problems. The shocks are easy squeezy. The struts are a little more challenging. I got the passenger side done and was starting on the driver's side, but can't finish.
There's this nut that has to come off. I think it's for the sway bar linkage. It's a 2?mm nut with an alan screw inside. I can't get them to break loose. I've tapped on them with a hammer. Soaked them with PB. I've almost rounded both off and before I do any more damage I need help. Is there a trick?
PLEASE HELP!
AlabamaDan
1998 Infiniti QX4
OK, it's the nuts on #16 in this illustration:
AlabamaDan
1998 Infiniti QX4
I checked close tonight and their both rounded out. Time for trip to the Junkyard - unless someone is parting out a qx4.
03Chillinkoot
Car: 2003 Nissan Pathfinder Chilkoot
AlabamaDan wrote:I bought some new shocks and struts for my 1998 QX4 and I'm havings some problems. The shocks are easy squeezy. The struts are a little more challenging. I got the passenger side done and was starting on the driver's side, but can't finish.
PLEASE HELP!
Yeah your right they are the links for the sway bar. Those nuts are are major pain to get off because there seized most of the time. Easiest way is to use torches too heat up the nut and blast it off with an impact gun. But you end up wrecking the nut and if not careful the link as well.
AlabamaDan
1998 Infiniti QX4
Ok, so who is parting out a QX4 that can sell me a sway bar linkage cheap? Is it the same exact part on a pathfinder?
fueler
Car: 2 Nissan's
2 BMW's
Make sure the nut on top of the strut (the one that holds the strut shaft attached to the top hat) is on very well. I now have 2 nuts, one on top of eachother, because I once had one back out on me while offroading. You do not want that to happen!
fueler
Car: 2 Nissan's
2 BMW's
AlabamaDan wrote:Ok, so who is parting out a QX4 that can sell me a sway bar linkage cheap? Is it the same exact part on a pathfinder?
It should be same as pathfinder but I could be wrong.
fueler
Car: 2 Nissan's
2 BMW's
This guy should have them for sale http://www.4x4parts.com/ubbthr...&vc=1
Acey
Car: 96 Pathy XE
When I priced mine out, they were $19.95 each at pepboys.
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
fueler wrote: I now have 2 nuts, one on top of eachother
Ouch . . . man . . I mean, I have 2 as well but they're next to each other sort of. :o
AlabamaDan
1998 Infiniti QX4
Bought a MOOG replacement for $20 at O'Rielly Auto Parts.
fueler
Car: 2 Nissan's
2 BMW's
yeah i think anyone who wears boxers has 1 nut longer than the other, because when you walk, they bang side by side until eventually one droops lower than the other so the nuts dont bang into eachother!!
KoukiS14
fueler wrote: yeah i think anyone who wears boxers has 1 nut longer than the other, because when you walk, they bang side by side until eventually one droops lower than the other so the nuts dont bang into eachother!!
Well, I certainly subscribe to that theory -- so far, so good!
man, this topic sounds like something they'd have in the moderator forum. . filthy bastards.
