HELP: front suspension noise after installing new cv boot?
fukkeneh240
Car: 1991 240sx and 1993 240sx ka-t
hello, this is for a 1997 4x4 R50.
sorry, but kinda long. searched but no exact luck. posted in another forum too. .
yesterday i installed new kyb gr2 fronts struts and monroe senstrac rear shocks... anyways while doing the driver side front strut i noticed the outer cv boot was torn. so after i installed all the new components i drove to the parts store to get a new cv boot. side note ... way better drive with the new suspension and none of these problems existed after i installed the new shocks/struts.
so after i get home from the parts store with the new outer cv boot, i installed the new outer cv boot by removing the axle and what not. i reinstalled everything and now i have some kind of light constant thumping/ticking noise when i drive... tick tick tick tick tick kinda sound. the sound is constant no matter if i turn left or right or stopping while driving.
ALSO i get a second LOUD rubbing noise that sounds like the caliper or brake pad is warped or imbalanced and brake pad is hitting a wobbling caliper. not a metal to metal scraping sound but an "UR UR UR UR UR UR UR" kind of sound. this sound goes away when i make a right turn and does not go away during braking.
i took a look at it this morning and noticed that weather/dust shield was bent and making contact with the caliper. straightened the shield, took it for a quick spin, both noises are still there. then inspected the brakes and they seemed fine, even took off the caliper thinking the shims could be off. reinstalled the brakes and took it for a spin and still the same noise.
did i screw up cv axle installation or something? every appears fine and nothing is loose. is there some kind of special way to replace the boot that is model specific for the R50? the old boot was about 6 inches long, and the new boot is about 4 inches.
I did notice that the lower ball joint (i think that is what it is, connects the bottom of the caliper to the suspension arm) was leaking a bit of grease, but my dad said that wouldn't cause the noise. Driving the car feels fine, and only problem is the annoying noise. the best search result i found was repacking of the wheel bearing?? i doubt that would be it though.
any help please?
update: okay just took it for a short spin to drop the misses off at the bus stop, that tick tick tick sound is more like a quiet thud thud thud sound; and that ur ur ur ur sound is ur ur urrrrRRrrr ur ur ur ur then quiet then Urr ur ur ...
haha, sorry for the bad description.
keelhaul
same answer on npora. check the cv boot clamp. It might be hitting lower control arm
