ShionS14 »
https://forums.nicoclub.com/shions14-u7970.html
Tue May 31, 2005 8:13 am
i wouldnt call myself a god but i would suggest first to pull your plugs and look at them, if they are white and deteriating then you are running lean and if they are black and gunked up you are running rich. if your car is obdII you have to remember that the second o2 sensor needs to be behind the cat. the second o2 basically determines if your ecu will run an open or closed loop fuel setup. secondly, what octane did you run before? switching octanes can play with the cars ecu, which it doesnt like to be toyed with. finally the cat holds a lot of heat along with the header pipe if its ceramic coated and any excess fuel that isnt burned during combustion will actually ignite with a flame front on the verge of detonation which is why you here the poppong in exhaust system. i personally have an aem intake hotshot header, no cat except that hollow secondary dumby cat that nissan puts in and greddy sp exhaust. my secondary o2 is disconnected which throws an engine code but runs just fine and it has a nice little gurgling pop when ever i down shift. as for as the glittery crap coming out of your exhaust you got me beat, maybe its fairy dust?
