help from china
miaqi632
china?seems a lit bit far away? hey, everybuddy, i am a new owner of G35, 2007 seden, the one with VQ35HR.not quite familar with many figures of my car, but i really want to do sth to make it move faster, and safer.now i need your help.
wheel question 1about wheel, can i put 18*8.5J at front, and 18*9.5J at rear? i am not sure if a wheel with the width of 8.5J or 9.5J fits this car. some suggests me to use 7.5J, but i think its too...not obvious
wheel question 2do they(front and rear wheels) need same offset value?(say +25 for LMGT4)what's the original value?
Tire question what tire do you suggest to fit LMGT4? i want comfort + sport.is P275/40R18 a good choice to G35? (if a 9.5J wheel fits)
brake questionsomebody suggestd AP racing front 6 with 355, rear4 with 330. is it a good choice?
still no ideas for suspension (i want comfrot +sport). may do sth about supercharger, but seems not quite a lot products for VQ35HR.
silnismo
Those size rims will fit, as long as you have the proper offset.
remember, 0 offset is dead center of the rim.
the lesser the offset the more the wheel will stick out, too little offset might cause fender rub.
i don't have an g35 sedan so i dont know the best offset, but the same offset on a stagg setup is fine.
Im running 35 offset all around with 17/8F 17/9R with no problems.
silnismo
For your brake question, if you got the mullah then go for the AP brakes, but the cost effective way would to either get the g35coupe/350z brembo calipers or the r33-r34 brember calipers which are bolt on and also cheaper.
Dunno about tires, but for suspension either go for shock and spring combo for guarentee comfort for DD (EX. kybs agx S-techs) or coilovers for noticable harsher ride but performs better.
GO YAO MING & YI JAIN LIAN!! repsenting china.
