help from all
nissansilvia89
ok i have a 1989 240sx fastback which i retained from a junkyard...right now the back a-arm is bent( the car was in a wreck got hit right behind the passenger door)...and also the lug bolts need replaced on the car...well basically my question is one...who would i know if the frame was bent..and two is this car worth tyring to fix..i really want to out a sr20det black top in it but i dont know is its worth it...u guys tell me if its worth it and if not what would u recommend out of anything out there for around 300-500 for a project car???
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
I don't understand your last question exactly, but as far as the frame goes, a competent body shop should be able to tell you. Does the car drive? Dumping money into a car can be a losing proposition, so if you decide it's worth it to you, then it's worth it. Just remember that cars are a bad investment typically and you probably won't get back what you put into it.
Andy
Eklectrick
Car: Photography, Computing
dude, i think someone switched some keys around on your keyboard or something.If you got the car for free and it runs, then hey! free car. I don't think anyone will be able to tell you if the car is worth trying to fix without actually seeing it. otherwise for 300-500 get yourself a Civic CRX hf and put an ls or b16 motor in it. that would be a fairly cheap project car.
