pachano00 wrote:What would happen if I give him 0.30
I don't think two separate threads are needed for the same discussion, so I'll just continue here.
As we mentioned already, there are no +0.30 oversize bearing shells for the CA. There are +0.25, +0.50, +0.75s. So it will be VERY hard to find someone who has tried 0.30. What you should ask is:
What would happen, if the crank is at 0.50? How many have tried it, and how many miles on it so far?
I know you are looking for a YES, and if you look hard enough, somewhere you will find that ONE 'yes' you need. But still, if you want to do it RIGHT, you should get a +0 crankshaft, or +0.25 maximum.
