platez808 »
https://forums.nicoclub.com/platez808-u98033.html
Thu Aug 13, 2009 11:54 am
I'm pretty sure that i didn't reverse it. Like how you did in your conversion, my hole that i drilled for the TAM signal is right by the plug right over the actual TAM copper connector thing. But it does look like there was a short and totally annihilated that resistor.
In other news, someone did try to check their ECU for me and found that it was a beige resistor with brown, black, black, and gold stripes from L-R. This should make a 10ohm +/-5% tolerance. Can anyone verify this for me please? I still need to identify the black one in the back. I know it says ES on the top and then 3 numbers/letters on the bottom, but I'm unclear on the bottom set. So yeah, let me know. Thanks again.
