red240ne wrote:...I had a leak problem in a diff once, after I had removed it. I drove it about 100 miles before I fixed it. Diff still worked great after that.
Yeah but your diff had run in oil for a long time, so had some residual oil on the gears and bearings. A rebuilt diff would have been pretty much dry. And still you were lucky.
The pinion bearing takes the most load, if the bearing is OK you're looking good for the rest of the diff. But if the diff is making noise it is fried. You should be able to see damage to the crown and pinion, either pitting or burning of the gear teeth.
