Alibireason wrote: ↑Tue Mar 02, 2021 6:18 pm
Thank you so much! Any particular kind of JB Weld I should use? Could adding the JB weld hamper future attempts to remove the screw? Wire brushing to score the surface so the weld sets better, correct?
You shouldn't ever need to remove that screw unless you're trying to do a DIY starter rebuild. It's part of the starter assembly and not really part of the truck or engine. Chances are if the starter ever goes, you'll just be replacing the whole thing.
Any kind of JB will work fine as long as you clean and brush the surface well to get adhesion. I prefer the putty for cracks like that, since you can finger-pressure it deep into the fissures.
