help for new owner 97 q45
harv3317
Car: 1997 infiniti q45t
hi, got it today, 46000 miles. nice! a couple of questions1- my infiniti q45 comes with 215/60-16 tires, will a 225/60-16 tire work well? i need tires and can get a deal on the 225 tires.2- are there any upgrades, or changes in the fluid requirements for the q? for example i have a lincoln mark 8 and we were told to upgrade the transmission fluid from mercon 3 to mercon 5. any such recomendations for the q?3-i've been using 10w-30 engine oil in my mark. i live in south florida and don't get much cold weather. can and should i use this weight oil in the q?4- i live in jupiter, fl. any members in the vicinity and any recomendations for mechanic's in my area?
look forward to many happy years with the Q45!!!!thanks for you help.
Nick240sx
Car: 2009 Ford Fusion SE Sport
well you picked a good car. my shop teacher has two mark 8s. nice cars.
your gonna get just as much power, just with 2 extra doors. good luck with the car.
i will let some of the Q gurus answer your questions for you.
VJ1
Car: 1994 Q45 Ivory Quartz 1994 Q45 Beige Sand 2009 Nissan Sentra White
Welcome to Nico. First of all, read everything on http://www.q45.org, and then devote alot of time to reading the archives on this site. I'm in West Palm and I have not found a Q45 tech around here whom I trust. I'm sure everyone will agree that you should not let the average "mechanic" work on your car.Post here any problems you may encounter before anything else. The moderators here can help you alot better than any mechanic.Since I'm a G50 guy and not Y33 I'll let the the experts chime in on your questions.Vandi.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
harv3317 wrote:hi, got it today, 46000 miles. nice! a couple of questions1- my infiniti q45 comes with 215/60-16 tires, will a 225/60-16 tire work well? i need tires and can get a deal on the 225 tires.2- are there any upgrades, or changes in the fluid requirements for the q? for example i have a lincoln mark 8 and we were told to upgrade the transmission fluid from mercon 3 to mercon 5. any such recomendations for the q?3-i've been using 10w-30 engine oil in my mark. i live in south florida and don't get much cold weather. can and should i use this weight oil in the q?4- i live in jupiter, fl. any members in the vicinity and any recomendations for mechanic's in my area?
Congratulations!
1.) Since the tires are the only part of the vehicl that interfaces with the road, don't skimp here. Read the sticky tire thread in Infiniti General for starters, and tire rack reviews for more information.
2.) Many use sy thetic ATF with an aftermarket ATF cooler. Some Lube Guard REd may be in order with a change. A mechanical fluid exchange, pan drop, and filter replacement right now could add many miles to your transmission. http://www.bgfindashop.com
3.) 10W- 30 will work fine if it is changed every 3.75K miles. I recommend the M1 filters from Joe over OEM thimbles.
