95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Thu Sep 14, 2006 8:26 pm
this could be out of the subject, but i would check the freon, or electrical..... AC units in these cars have a safety, if the freon is low, it cuts out the ac compressor, and no matter what you do, it will not kick back in untill you fill it up again. it was raining all day here too, and the amb temperature was showing 64 F, however, i didnt have a problem with the AC, i hope this helps figuring out the problem. good luck
by the way, when you press the AUTO button in the j, the AC compressor turns on no matter what the ambiant temperature is
