ddgsxr504 »
https://forums.nicoclub.com/ddgsxr504-u24314.html
Wed Oct 18, 2006 6:12 am
By searching NICO I found the wiring diagram on how to bypass the switch in the headlight stalk.
The fog lights only work when you have the headlights on and when the high beams are off, if you look at the diagram you need to spice a wire inbetween the power to the headlight stalk power wire and the wire that runs to fogs when proper criteria is met for them to be on. That way no matter what position the headlight stalk is at the fog lights will always be recieving power.
Just remember not to leave them on.
Modified by ddgsxr504 at 3:23 PM 10/19/2006
