tmorgan4 wrote:Just to be clear, the engine was NOT running when it happened, right? Sounds like you were just trying to start it and it never did.
These side feed injector O-rings are notorious for leaking. I found that out after I talked to a local race shop saying I had a leaking injector O-ring and they weren't surprised. Mine isn't as bad as yours, though.
The gas should evaporate pretty quickly on it's own. I'd change the oil since you've now got gas leaking down past the rings and into your oil. I'd also try and turn the engine over by hand on the crank bolt instead of continuing to use the starter.
It definitely wouldn't hurt to pull the plugs and let the chamber sit open for a little bit. If you pull the plugs, turn the engine over a few times by hand and see if any gas comes out of the spark plug holes.
Stranger things have happened, but I'd be VERY surprised if you did any damage to the engine. I hydrolocked my VG33 and bent a rod severely but the engine was on the rev limiter when it sucked up about a gallon of water.
When you put the O-rings back in, make sure to grease them with a suitable lube (my Deatschwerks injectors included some stuff called "Super Lube") and make sure not to "roll" them. Easier said than done considering I've got a bad one too!
Correct. it was NOT running. JUst trying to crank it over. and it didn't even budge.
Is wd-40 ok to use?
And also, when installing the lower o-rings. Do i put them in the fuel rail and not on the tip of the injector? Cuz i put them on the tip of the injector and it seemed to not get in the little divet in the fuel rail. The fsm doesn't say anything on installing the o-rings
Thanks for you quick response by the way!!
