Help! First time engine build, having belt problems!
saintnick83
Car: 1993 Nissan 240sx HB w/ built KA24DE
Long time reader, first time posting. I purchased a wrecked 240 (I think it's a 1991) to build the engine in and swap into my 93 HB. The build went fine and the engine is in, but I've run into a speed bump. My 93 HB has HICAS four-wheel steering. The engine I installed was from a car that did not have HICAS. All of the accessories I bolted onto the new engine were from the 93 except for the power steering pump; only the 91 would fit. The problem I've run into is that all of the accessory pulleys are 3-band pulleys (Alternator, Crank, Water Pump) but the water pump and it is a four-band pulley. So, does anyone have any suggestions for making this work as is or what I should replace it with. (The pulley is a press on so I can't swap the pulley and my HICAS pump won't bolt to the non-HICAS block.) Or, does anyone have non-HICAS crank and water pump pulleys for sale? My car has been garaged since November! I just want to drive it!
