Help finding a dash harness plug??
420_240
Hey fellas i need some help and i can't find it anywhere! I've posted this in the rb section but i figure i'd get it spread out for some more assistance. To bring you up to date... i'm currently finishing up my swap of an rb25det into my 95 s14 SE. Only problem is... i cannot get power to my fuel pump because of a plug i cannot find. I've trace the wires from the plugs on top of the fuel pump... onto the top of the passenger side rear strut mount... down the back passenger seat... and underneath the carpeting... this is where the problem lies....I have the body harness that attatches to the tail harness and branches off to the fuel pump.... What i'm MISSING is the dash harness plug, that goes to the body harness plug. The body harness plug should connect to the dash harness plug and continue to the fuesbox/relays to power the fuel pump....Here is a picture of the body harness plug... this is the plug that connects to the MISSING dash harness plug...
420_240
here's a diagram to help get my point across a little easier.... this is a diagram of the body harness that connects to the fuel pump... the picture i have posted above is the end of this harness...
420_240
Here is a diagram of the dash harness that shows where the body harness connects and runs to the fusebox/relays.... I've taken my dashboard almost completely apart looking for this plug and still cannot find it... could someone post a pic of how theirs is set up so i can get an idea of what this missing plug looks like??? thanx for your help fellas i'm dieing to get this thing running!!!
