Uploaded with ImageShack.us
I imagine it is a feed (water line) for the turbo if you still have the stock T25 turbo??? other then that i have no clue....patrickm1587 wrote:Well I don't know, I thought it might have connected to something on the intake mani but you said it was water leaking. Hmm... That's not the feed line for the turbo is it?!
Actually now that I've thought about it, I think that is the feed line for the turbo. But like turbonxsx said, are you still running the stock turbo? Even if you weren't you would still need to get water from that location I would think, or at least I did. Unless for some reason you are getting it from somewhere else. I'll look at mine when I get time.turbonxsx wrote:I imagine it is a feed (water line) for the turbo if you still have the stock T25 turbo??? other then that i have no clue....patrickm1587 wrote:Well I don't know, I thought it might have connected to something on the intake mani but you said it was water leaking. Hmm... That's not the feed line for the turbo is it?!
