help fast!!!!! first start!!!
blacktop sr20kid
Car: 1990 240sx
ok so i "primed" my car by unpluggin the CAF and turning over 2x for 15 sec.then i satarted and let it idle for 10 min.
Theres lots of smoke comming from the manifold and turbo and when i give it gas the idle drops to 500 and then returns to a steady 1000rpm.
is this normal... any ideas?
mutiny
Car: 1989 240SX
is this after a fresh rebuild or just motor swap?
im having the exact same symptons on a ka24e rebuild, but im thinking:
a) its because of the oil i spilled on the valve cover/manifoldb) its normal for rebuilds to smoke at first (though through the manifold?)
as for the idle thing, maybe check timing/sensors?
blacktop sr20kid
Car: 1990 240sx
So my car doesn't smoke anymore but it still drops to like 500rpms after i rev it????? it sometimes even dies??? anyone ever had this problem?
and its a swap not a rebuild?
spoolin_s14
Car: 95s14
is the bov vented or recirculated?
you might want to reset the timing also
