i2ice4m3 »
https://forums.nicoclub.com/i2ice4m3-u3901.html
Wed Jul 16, 2003 7:55 am
My ecu gave a code 45, and it seemed to be running rich because i there's a strong gas smell from the exhaust when i start the car cold. I removed the fuel rail with the injectors still on and turned the iginition on. nothing leaked . no dripping gas from the injector spraying part (?). I did a search and this guy got a code 45 also, but it turned out to be his fuel pump. How does the ecu know what code to put out? are the codes more of a guideline to where to look (in my case, the fuel system)? My car wont pass emissions because of high CO emissions at idle. above 2.5k rpm is fine though. I changed the water temp sensor and the ecu is giving code 45. Thanks everyone!
