Help:Failed Smog Check!!!
second2nones14
I just went to get my smog check and i failed. The Paper said i failed on "NO (PPM)" -(15mph) MAx=704 Ave=150 Meas= 1548 -(25mph) Max=738 Ave=136 Meas= 1601
IT FAILED
95 240sx Auto 145kThis is What i HAve on My car=CAt Back ExhaustInjen WAI (carb Legal)New PlugsZ32 Fuel Filter ( Could This Be It???)
So Anyone Want to Shead Some Light Here, Thanks?BTW- Im In CAli
Modified by second2nones14 at 1:17 PM 7/8/2005
InsanityInc
Something is wrong with your EGR system. It's most likely just stuck. Put your hand underneath the valve and manually actuate it a few times. Then turn the car on, rev it up and make sure the valve moves when you get it above 2500 or so.
second2nones14
Where is this egr (Exhaust Gas Recirculation) valve located in the engine compartment?
navysnail
if you have a silencer in your exhaust, use it. EGR is under the intake manifold toward the back of the engine.
NISTECH
I have pictures posted in this forum of the egr try a quick search. Also it would help if you would post the results of the other 4 gases as well as the max and average values of HC and CO.
second2nones14
I'll do a search.
More info....-15mph at 1734 rpm % CO2 Meas 14.6 %02 Meas 0.7 HC(ppm) MAx=88 Ave=21 Meas=29 CO(%) Max= .52 Ave=0.06 Meas=0.01 NO (PPM) MAx=704 Ave=150 Meas=1548
-25mph @ 1771rpm %CO2 Meas 14.6 %02 Meas 0.9 HC(ppm) MAx=53 Ave=13 Meas=24 CO(%) Max= .50 Ave=0.05 Meas=0.01 NO (PPM) MAx=738 Ave=136 Meas=1601
NISTECH
2 gold suacers at the back of your intake. The top one has 2 vaccum lines on it and one goes to the bottom saucer. That is your EGR and BPT. The BPT is the top one. Underneath it is a rubber hose going to a steel tube. Check to make sure that hose is in one peice. not soft or burnt out. Your problem is mearly EGR not functioning. All your other readings are with in normal levels.
second2nones14
alight im going to give it a check tomorrow when the suns out. so if it is burnt or soft, all i have to do is replace it?
I also bought a new fuel filter to get it back to the original spec filter.
NISTECH
The fuel filter will have nothing to do with it. You one of thousands failing the smog checks in the bay area right now. This is due to them making the bay area an enhanced area last year. The enhanced smog program uses the dyno to measure Nox. That is the difference from the program you guys used to be on and the new program. So tons of people that passed smog on their last biannual inspection are now failing due to poor EGR operation. What I am suprised abut is they gave you guys the same standards we have out here in the valley. We have been enhanced out here since 98. When they started the enhanced program the max numbers were much higher to avoid cosumer backlash from mass failures so they gradually stepped the max allowable down over a 4 yr period. It is speculated it will go lower over the next couple of yrs.
second2nones14
The Egr dont seem to have any kind of detereoration ( cracks or soft or burnt). do you know if its anything else. I just put back the stock intake box and piping back btw, i hope something would help.
zer0c123
Car: 1993 Nissan 240SX Hatch
I failed smog twice before i passed. It might be that your egr passages are all clogged up, like mine were.
link to my old thread
zerothread?id=118420
hazw8st
Looking at the readings, are you sure your EGR is even hooked up?
