PUMA26 »
https://forums.nicoclub.com/puma26-u151884.html
Tue Mar 29, 2011 11:43 pm
I have a 94 z32 tt, I met in an accident a while back with a semi and he pretty much tore the driver side door apart. So I found a door from the junk yard and used that. The windows will not work now, so I try to fix or find the problem thinking it's probably the window motor or regulator upon diagnosing the issue the windows start working I don't really know how but they do. I'm assuming i triggered the factory alarm and the car will not start. I tried everything to start the car, cycling the key, disconnecting the theft module, disconnecting the ecu, and taking the neg. battery cable off and let it sit. Nothing works and neither the car nor the windows will work. Please If anyone can help it is greatly appreciated.
