New here, I have a 89' 240sx 5sp. It ran fine until I tried to start it up to go home from work and there seams to be power to everything but the engine does not crank. Battery looks to be at a little over 12V. Since I am at work its hard to work on. The ignition switch seams to be working --Headlights work, dash, fan etc. work. Its hard to tell if the fuel pump is running since there are too many other sounds around (near the highway).
What should I look at? Any relays or fuses? I do have a box of relays that I salvaged from a junk yard.
