t.mcginley.jr wrote:Did you manage to ohm test the #1 injector with a multimeter yet? that will tell you if it really is bad or not. If all the injectors are stock though, it could be a matter of time before the rest go bad
no, couldnt find my meter cables. go figure. will test tomorrow. buying new one. uf the injector ohms out good, can it still be bad???
