xGUNKx wrote: (interior and nos mabe)
were the f*** did the face palm icon go
anyway your getting a 95 s14 i dont see alot of swaps go into zenkis other than sr20's maybe a few RBsswapping in a ls motor is not a simple plug n play swap if this kid is going to do it for you, you better make sure he knows what hes doing and do ALOT of research on the swap.
PS you can use the stock ka24de block and use the money instead of swapping a new engine, just build your KA super beefy. Reinforce the internals and you can then push higher boost and get lots of power.
Modified by Klits562 at 7:52 PM 10/15/2009
