yellow_jacket »
https://forums.nicoclub.com/yellow-jacket-u4236.html
Fri Feb 21, 2003 3:51 am
If the heater wasn't working and your car was running in the normal zone, more than likely you are out of coolant. Wait til the car is very cool, take the radiator cap off, fill it til it overflows. Then fil the over flow tank up to the cold mark. You may have to repeat the process due to an air pocket, but you should be ok. The burning smell was more than likely the smell of a very, very hot motor.
