Help! Engine not reving over 2500RPM
huda424
Car: silvia s14
i was going 50 on one of the roads near my house when i heard a loud banging sound.( sounded like something hit my car) all of a sudden my car would not rev over 3000 rpms. i drove it home and inspected the car. i noticed that the 02 sensor plug fell and touched the turbo manifold and melted. i quickly cut it off and spliced it back on. i turn on the car again and ried to rev it. the car stalled. i then checked my maf and i noticed that the maf was cracked. luckly i had a n62 maf at home so i swapped that in today. i just turn on the car and noticed that the car runs really good but it would not rev past 2500 rpm. what could be the problem? any help would be great. Thanks in advance!Btw this is the same post on zilvia
Sileighty_85
Car: 1991 180SX
Is you ECU tuned for an N62 MAF?
You cant just throw on a MAF without a tune.
Modified by Sileighty_85 at 3:20 PM 3/29/2009
huda424
Car: silvia s14
yea the maf revs as smooth as the old one it just cuts off at 2500 though.
huda424
Car: silvia s14
yea i tuned the safc II settings to 2in 6 out
johnny5
Car: 91 red 240 hatch
sounds like the ecu is in limp mode disconnect the battery full and let it sit for 30 min then reconnect everything and see if resetting the ecu works
huda424
Car: silvia s14
disconnected the battery now the safc II shows air flow at 100%
huda424
Car: silvia s14
ok switched the maf wiring around and its reading 16% but the car stalls out now. what could be the problem? still the maf???
