Help Electronic Problem! 1995 Nissan 240sx, Turn signals and Dash Lights
ruski240
Car: Nissan 240sx
Ok I have a problem,
First, my turn signals don't work. When I try using them nothing shows or blinks no noise nothing. But my hazards work!? I checked fuses they're ok, whats up?
Second, when i turn my headlights on at night my dash lights dont work and the rest of the glow lights dont either. I cant see anything. I also checked fuses, they good.
I am clueless if anyone has any ideas let me know.
MaximA32
Check the in-dash relays for the turn signals.
ruski240
Car: Nissan 240sx
Were exactly would the relays be for the turn signals? Would you know?Thanks
dark240kid
Car: 240sx
did you figure out the problem? cause im having the same problem with my dash
ruski240
Car: Nissan 240sx
Ok I check everything I can think of, and it all looks good (fuses, relay, switch good). I took it to the dealer they're telling me its the wiring somewhere. I checked it out and now my gas gauge isn't working right. I am going crazy! If anyone got tips or may be a diagram of the wiring that I should check, that would be great. Otherwise I am at a dead end
ruski240
Car: Nissan 240sx
I figured out why the dash lights didn't work the control to adjust the brightness had a bad connection so I took it apart and used brake cleaner to clean it out, now it seems fine. I don't know about the rest yet still working.
